rhagfo
Aug 28, 2017Explorer III
Garyl53 wrote:
Hi,
Here is an update from the OP:
I was able to locate some 5200 lb. front coil springs for a reasonable price so I removed the 6000 lb. plow package springs. This resulted in a slightly better unloaded ride but nothing significant. I just returned a camping weekend and I would say that the new front springs had the effect of making the "chucking" just slightly less severe. The "chucking" was still very much present but the amplitude or severity of the "push-pull" feeling was a little less. Unfortunately it will need to get a lot better or I will have to look into a new trailer and/or truck combo. I am planning on finding someone local to pull my 5th wheel just to see if they also experience the issue when using a different tow vehicle.
Again thanks for all of your suggestions and please post anymore ideas about this issue.
Gary, what air pressure are you running in the front tires? I don't run 80 psi in the fronts between 60 and 65 psi should be correct for the load they are carrying. You also might look at the load on the rear tires and drop the pressure to about 75 psi.
To all that say too much 5er for your F250, I carry and pull likely the same size 5er with my 2001 Ram 2500, I don't have bags just a tow and camper package, and a optional 265/75-16 E tire rated at 3,415# ea.
About Fifth Wheel Group
