danrclem
Aug 29, 2017Explorer
Garyl53 wrote:
Danrclem - changing the springs was about a two hour job, mostly setting up the jack and jack stands correctly. I just removed the wheels, removed the screw holding the brake line bracket to create some slack, removed the front sway bar from the top of the links and then lowered the axle. Springs can then be lifted out quite easily and replaced. The front height only lowered about 3/4 of an inch.
Thanks for the info. Hope you get everything sorted out.
About Fifth Wheel Group
