Njmurvin
May 20, 2013Explorer II
atvanish wrote:
My head is spinning trying to understand two potentially debatable questions after my research. I pretty much gave up on getting a fifth wheel due to my truck height until I had to tow an old one this weekend and remembered how nice they tow. My truck is ~2-3" taller than a 'normal' 2500/3500 keep in mind...
1) How nose high is acceptable? My understanding is equalizer axles are designed to accommodate this...
2) Do any manufacturers allow/warranty GN adapters? Trailer I towed had one...
Constructive thought would be appreciated! :)
I had this with my trailer. There is a certain amount of equalizing of weight between the axles of the trailer. That said, I had my axles flipped on my trailer (leafs moved on top of axle instead of under). There was a kit for this and I recall it only costing me a couple of hundred total. Yes, the trailer rides higher, but that's not all bad. You get better ground clearance and don't have to bend over as much to get to things that are low on the trailer. If you do this I would recommend getting steps to accommodate the new height (my last step is a doozy). Some trailers have some adjustment built in. Mine didn't.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 22, 2026
