laknox
Dec 24, 2015Nomad
Air Boss, I agree with the others, replace the tires with a good tire as soon as you can; put the ones that came with the FW on Craigslist and you should recover a good portion. If you have 16" rims, go with a good LT tire or, if you've got a heavy FW, with an even heavier G or H rated tire; just make sure your rims are rated for 100+ psi. Also, make sure that any tires you get, now or in the future, are fresh. There is a date code on all tires and make sure you tell the dealer that you don't want tires more than 6 months old, if that. Using Search on here is your friend, and you'll find dozens of threads about tires. If you also post more details about your FW and truck, you'll also get more info right up front.
Lyle
Lyle
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 23, 2026
