SLE's avatar
SLE
Ultraheat Melted Black Water Tank!
So, I come back from fishing to a prominent sewer smell. Look under the Cedar Creek and noticed a drip from the belly pan. Figured a fitting or something was leaking. Pulled the belly pan and insulation (which was a bit of a nasty job when it's full of sewage!) and start inspecting for a leak. Notice a very slight drip coming from the tape pad that holds the Ultraheat tank heater to the tank. I reach up and touch the tank heater and notice the darn thing is hot! WTH, I get out from under and go into the RV expecting one of the kids flipped the switch on and see that everything is off as it should be. Of course I grilled everyone and nobody had touched it. I went back out, snipped the wires and pulled it off to find it melted a fairly significant hole in the tank (that sucks).
This is where it gets interesting. I pull the pan for the grey tank and touch the heater and notice it's warm but not near as hot as the one I had just removed. Go back in and check the switches to see that they are indeed still off. Start checking a few things with my limited tools and decided I must a have a short somewhere and decide to just remove the 15 amp fuse that runs the tank heaters and the monitor panel. Low and behold and hour later the damn pad is still warm! At this point, I decide I better check the galley tank. Pull the pan to find that one is cold. Well this makes some sense as this heater is on a separate switch from the other two. At this point I clip the wires to the grey tank heater and taped off all of the wires to make sure I don't burn a hole in the grey tank also.
I'll be taking the multi-meter with me back to the lake next weekend to do some checking. If anybody has any suggestions where to start I'm all ears! Second, has anybody had any luck patching a tank? I am hoping to epoxy or jb weld the hole shut as a temporary fix until I can get it home to be worked on. If anyone has some advise, feel free.
Thanks
  • I think I would Remove wiring all the wiring going to those pads and reinstall everything with new wiring and pads. If you use them. If you removed the correct fuse and there is still power there, you have to have some wires shorted so power is coming through another fuse. Hook up the multi-meter and pull fuses one at a time until you lose power to those heater wires. Then figure out if it is wired to that fuse or if a few wires have been rubbed enough to remove the insulation and short together.
  • I can't help you with the first part really.....just sounds like a short somewhere. Have you checked that switch to make sure it's not bad? I would think it almost has to be either in the switch or between the switch and heater.
    I would make a patch for that tank and epoxy it on there really good. I see no reason why that wouldn't work. Just make sure it's clean and dry before you do it.
  • WATER WELD by j-b weld.
    Drinking water safe
    Repair and Seal underwater or in wet conditions
    Ace Hardware carries it.
    You can actually permanently patch a hole under water with it! It comes in a tube the size of a jumbo crayon. It's 2 colored putty, mix together and slap it on. Dries as hard as concrete that you can drill it or sand it. I've used it several times and it's a permanent fix that works when it comes to water items.
    This stuff is incredible. You most likely will not have to even drop it to have it repaired after you patch it with this stuff.
    check the specs out here
    http://www.jbweld.com/product/j-b-waterweld/
