Steakman
Jul 16, 2014Explorer
Wow...I'm floored that anyone would want to pull a 5'er with an F150, or a Sierra 1500 or Dodge 1500....
I had a hell of time finding a 5'er that I could safely pull with my 2500 HD diesel. I finally found a 30' Chaparall that was 8045 dry with a pin weight loaded of ~ 1500-1800 lbs....and i'm still over. My truck is 9200 GVWR. I added a road master Active suspension to it and so far so good...but an F150.???
Really.?
You may want to look at Weights:
GVWR of your truck.
So the weight of everything in your truck incl passengers and their stuff + pin weight. And you will want 15-20% of the 5th wheels weight on the pin...loading it heavy in the rear to transfer/save pin weight is a recipe for disaster.
Anyway..I do see weights coming down...not sure if that is a good thing or not. In heavy cross winds..likely NOT. However I would be very curious to see the 5th wheel you can SAFELY / Legally tow with an F-150 after that calculation.
stk
I too would recommend a TT with a max of 6000 lbs - Seems to me you'll get way more trailer for your money.
Really.?
GVWR of your truck.
stk
About Fifth Wheel Group
19,042 PostsLatest Activity: Apr 15, 2026
