Tony_B's avatar
Tony_B
Un-Hitching a 5th Wheel
I'm new at this. Only did it one time and that was with assistance. The following is according to my best recollection.
All suggestions will be appreciated
1). Lower tailgate
2). Lower front legs down 1/2 way using electric switch
3). Lower the rest of the front legs by pulling pins and letting drop to floor.
4). Insert pins back into legs
5). Raise front legs of RV to take pressure off pin in hitch
6). Drop rear legs to about 1 -2 " from ground and insert pin
7). Chock the tires
8). Pull pin unlocking the hitch handle
9). Release the hitch
10). Disconnect safety breakaway wire
11). Disconnect cable from trailer lights to truck
12). Pull truck away from camper
13). Use self leveler
  • Chocking the tires should be #1 and in bold red print.
    Don't buy the pretty yellow plastic ones. Northern Tool has some hard rubber ones with a handle on sale for <$5.
  • I pretty much agree with what laknox notes, except for 2 and 3. I use 4"x6" wood blocks about 12" long under my front jacks. I put the blocks under the jacks without lowering them electrically at all. Then I just pull the pins and let the jacks drop on the blocks. But I do have JT Strongarms to take out any wiggle there may be due to leg height.
    And I do chock the tires before any thing else.
    1). Lower tailgate
    2). Lower front legs down 1/2 way using electric switch - Or more... The less you have the extensions out, the less wiggle you'll have. Also, if you have something to put under the landing legs, it will help keep them from sinking. If you use a =thick= block, you won't have to extend them as far and this will also help with wiggle.
    3). Lower the rest of the front legs by pulling pins and letting drop to floor. - See above...
    6). Drop rear legs to about 1 -2 " from ground and insert pin - I wouldn't do this until the truck is clear of the FW and you can semi-level fore and aft, manually. =Then= drop your rear legs.
    7). Chock the tires - Personally, I do this as soon as I'm satisfied with my location. I don't want =any= fore/aft movement when I'm extending my landing legs.
    11). Disconnect cable from trailer lights to truck - IMO, #10 and #11 should be done =before= opening the hitch, but that's just me.
    12). Pull truck away from camper - This is where I'd drop the extensions on my rear leveling legs =after= getting it roughly level fore/aft with the landing legs.
    Lyle
