- fj12ryderExplorer IIIWell, the OP has never come back to expand on his problem, so we may never know. :)
My 2005 Keystone Big Sky had hydraulic landing gear, and I loved them, they worked so fast. Much better than the electric ones, IMO anyway. - BB_TXNomad
fj12ryder wrote:
After giving this some consideration, I think he has worse problems than finding the pump. I think they're under the impression there's a separate pump for the slides, because their slides won't move and they're trying to find the pump to see if it's too low on fluid to move the slides.
There's only one pump, and it should be in the front compartment.
Unlikely the 2007 Copper Canyon has hydraulic jacks. - fj12ryderExplorer IIIAfter giving this some consideration, I think he has worse problems than finding the pump. I think they're under the impression there's a separate pump for the slides, because their slides won't move and they're trying to find the pump to see if it's too low on fluid to move the slides.
There's only one pump, and it should be in the front compartment. - FlatBrokeExplorer IIMy bad, I was thinking hydraulic landing in gear which I miss that came with my Bighorn.
- BB_TXNomad
FlatBroke wrote:
2007 Keystone, I doubt had hydraulics.
My 2007 Keystone Montana had hydraulic slides. But the pump was very obvious when you opened the front compartment door. If several people can’t locate the pump then my guess is it doesn’t have one. - hornet28ExplorerMy 05 Mountaineer has the pump in the front storage compartment
- fj12ryderExplorer IIII had a 2005 Keystone with hydraulics, so it is possible. But are you sure it's hydraulic, and why do you need to find the pump? Have you tried using the hydraulics and followed the sound? Or followed the hoses from the front stabilizers? It's pretty good sized, so pretty hard to successfully hide. :)
- FlatBrokeExplorer II2007 Keystone, I doubt had hydraulics.
- BB_TXNomadMaybe you have cable slides rather than hydraulic slides.
About Fifth Wheel Group
