Ivylog's avatar
Ivylog
Explorer III
May 25, 2017
Unbelievable how cheap they can make them.
Friend has 2009 Forest River Sierra 5er. Supposed to have Laminated Vacuum Bonded Aluminum Sidewalls and it does in some areas but not in the back or in the rear side wall. Major water damage and side wall has no supports/framing for over 4' and it's just soft 2x2 wood (no alum in the sidewall) and styrofoam sandwiched between the outer skin and the lauan thin inside plywood. Hardly any calking in the 1" overlaps at corners and roof.
On the left side of the picture you can see the wall that runs from the back of the trailer forward 4' to the white area without any supports.
