hmknightnc wrote:
therink wrote:
VintageRacer wrote:
Sure, buy a different trailer. It meets specs but barely. What else is it telling you? Check your tire ratings. The last trailer I bought with 5200 lb axles didn't have tires up to that rating.
Brian
Tires are fine. Load range E 16" LTs. Tires far exceed axle ratinogs.
Well, that's good and wierd. If that is the case I would load it up and go a scale and get wieghed. If your under 5,200 on the axles I'd let'r rip. Are you sure they are 5,200# axles? All of the 5,200# axles If seen (and I have an equipment trailer with them) use 15" tires (load range D at 2680#). Those E 16" are 3k# rated
Yeah, I'm sure they are 5200 lb axles. They are six lug and I confirmed by the yellow sticker and the tags on the axles.
