FastEagle wrote:
therink wrote:
I have a Keystone Sydney 340fbh fifth wheel with 5,200 lb axles ( 6 lug wheels) 12,400 gvwr, dry weight of 10,600, leaving payload of 1,800lbs.
If I calculate 20% of Gvwr on the axles, the Gross axle load should be 9,920 or 4,960 per axle. Isn't this cutting it close. Also, I believe 1,800 payload is quite weak for a fiver this size.
Opinions?
Here is how I figured your weights using Keystone’s specs. They predicted a shipping weight of 10,544#. That would include all factory standards. To that they used 1856# of available cargo weight to establish a GVWR of 12,400#. By regulations they must set a hitch weight. In doing so it becomes the sounding board for determining the vehicle’s GAWR. So when we deduct the 2000# hitch weight from the 12,400# GVWR we get 10,400# supported by the axles. Thus two 5200# axles.
A double check of their specs can be done by adding the hitch weight to the GAWR. According to current regulations that answer must equal or be greater than GVWR.
So, on paper you have a cargo capacity of 1856# before dealer installed options. If your cargo label has a +/- 100# figure (before dealer options) I would say that is a good ballpark figure.
The following statement is verbatim from a NHTSA Q&A document.
“The FMVSS have requirements for the manufacturer to use proper tires and rims for the gross axle weight rating (GAWR) and the gross vehicle weight rating (GVWR). The manufacturer may determine the GVWR by adding cargo capacity (if any) to the curb weight of the vehicle as manufactured. The wise consumer, before purchase, will determine if the vehicle has sufficient cargo capacity to carry the weight of water, additional equipment (such as televisions, and microwave ovens), and luggage. The manufacturer’s certification label must show the GVWR. The GVWR must not be exceeded by overloading the vehicle. There is little the government can do to assist a consumer who has purchased a vehicle that has insufficient cargo capacity for its intended use.”
FastEagle
Thanks for the information. I will hit the scale tomorrow. I'm probably good, but still wish I had heavier axles for comfort factor.
Steve
