mapguy wrote:
FastEagle wrote:
mapguy wrote:
3. Safety margins are not "build-in" by most OEM RV builders. In fact -if you like to travel with potable water, more than one battery and LPG in the tanks - you risk being overweight.
The next paragraph is an out of context sentence from NHTSA regulations. The applicability means when such a system is installed.
“If applicable, the weight of full propane tanks must be included in the RV's UVW and the weight of on-board potable water must be treated as cargo.”
FastEagle
Nit-pic
Fine point
Propane calculation is always part of carrying capacity @ stated gvwr.
The proper term would be UVW.
FE
