therink's avatar
therink
Undersized axles?
I have a Keystone Sydney 340fbh fifth wheel with 5,200 lb axles ( 6 lug wheels) 12,400 gvwr, dry weight of 10,600, leaving payload of 1,800lbs.
If I calculate 20% of Gvwr on the axles, the Gross axle load should be 9,920 or 4,960 per axle. Isn't this cutting it close. Also, I believe 1,800 payload is quite weak for a fiver this size.
Opinions?
  • therink wrote:
    VintageRacer wrote:
    Sure, buy a different trailer. It meets specs but barely. What else is it telling you? Check your tire ratings. The last trailer I bought with 5200 lb axles didn't have tires up to that rating.
    Brian
    Tires are fine. Load range E 16" LTs. Tires far exceed axle ratings.
    Well, that's good and wierd. If that is the case I would load it up and go a scale and get wieghed. If your under 5,200 on the axles I'd let'r rip. Are you sure they are 5,200# axles? All of the 5,200# axles If seen (and I have an equipment trailer with them) use 15" tires (load range D at 2680#). Those E 16" are 3k# rated
  • Have you weighed your rig to see what your actual axle and pin weights are?
    The pin wt. could be much higher than 20%.
    Brian
  • Sure, buy a different trailer. It meets specs but barely. What else is it telling you? Check your tire ratings. The last trailer I bought with 5200 lb axles didn't have tires up to that rating.
    Brian
