g4sbrg's avatar
g4sbrg
understanding tire load rating
well I made my first long haul with my new to me 5ver, my 5ver did well being used I was very happy with it, how it pulled and maneuvered. that's why we buy 5vers isn't it. I did however have tire problem with my truck, (I should have known better) the truck was given to me and had some front end shimmy which went away when I rotated the tires. on my return leg off a 1000 mile trip I picked up a bad shimmy/vibration (slow you down to a crawl vibration) found a bad tire driver rear and mounted a spare, (this was the one I figure might have caused the slight vibration when in front) 100 miles up the road picked up another vibration and the other rear was going out)
so I hobbled back 10 miles to the nearest open store last night (Wal-Mart) put two new tires on the rear. tire guy told me the tires that came off were from 02 and probably went bad due to the load on that age of tire. Comments ? also with a tire rated at 80 psi max cold what do you recommend or prefer to pull at ?? I was set at 70 psi cold before I left on the trip.
  • I run the tire pressure listed on the sticker inside the door.
    On my current 3500 DRW, it says 70 front and 65 rear. Over 25,000 miles towing 5th wheels and the tires are wearing great.
    My last truck, 2009 Chevy 2500, was 72 on the rear. Instead I went for 80 and wore the tires out pretty quick.
    Check the tire pressure chart for your make of tire for the proper air pressure. It's not always best to run max sidewall pressure.
  • Sidewall of tire will state 'MAX Load Rating at MAX PSI---COLD'
    Because I run at max load I use max psi. Max is 80# on my tires---not the same for all tires.
    When not towing I use 45# in rear truck tires.
    What are your tires rated at and at what pressure?
    What is the weight on rear tires/axle of truck?
  • Towing a FW, I have my tires at the max. I run the rears at 80#s.
    The weight rating on your tire is figured at the max pressure.
    Jerry
