shadows4
Jun 23, 2016Nomad
Dave, I think you could get that fixed for far less than $10,000. I am going to show you a couple of pics of mine. Both sides, roughly straight through the bedroom window were cut off, about 5 foot each side. The repair shop ordered two panels that were laminated. They took those panels and cut them to fit and then fiberglassed the seam. The cost was approximately $3000 or $1500 per side.
I am sure you could find someone near you that repairs fiberglass sided RV's. Good luck to you sir.
If you look close here you can see the seam before I had it fixed.
Now the seam is gone.
This side was also repaired because of delamination from roof leak. Cut was straight down thru window.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 22, 2026
