Cummins12V98
Aug 17, 2016Explorer III
chrizg wrote:
Trailer tires need to be at MAX psi. If you have a blowout and they ask what psi they were at and if you say anything other than MAX they will deny the claim (info from treddit tire in Elkhart, IN)
That is NOT true!!! The reason most say MAX inflation is the RV Mfg lists their GVWR on what the 4 tires can carry. When up sizing/load ratings it is recommended to use the inflation chart and add 5psi to the heaviest tire on each axle.
About Fifth Wheel Group
