TxGearhead
Aug 18, 2016Explorer II
I found the post on the other forum and cut & pasted it:
RE: requesting technical specs s637
Alan Eagleson ([email protected])
[email protected]
The tire is designed to run up to the maximum air pressure at the maximum load at the rated speed. If you have the tire inflated to 80 psi and the load is below 3000 lbs. per tire, it will not over-heat. The speed rating is “L” which is maximum of 120 km/hr. The over-heating comes from running the tire more than 120 km/hr or under-inflated for the load or a combination of the two.
You should be good to go based on the information you have provided.
Al Eagleson ‘ACE’
Director, Commercial Truck Products
Sailun
[email protected]
Al Eagleson ‘ACE’
Sailun
About Fifth Wheel Group
