Cummins12V98
Aug 18, 2016Explorer III
TxGearhead wrote:
Looking at that pic of the label, one of the "bullet points", second from bottom: "After seating tire beads adjust inflation to pressure recommended by vehicle manufacturer". That would be what is on the decal on the side of the trailer; which would be 80psi if you are upgrading from OEM LR "E".
Rock & Roll
GY "G" inflation/weight table below. I ran 85psi on my GY "G" tires on my Avion that had GY Wrangler "E" from the factory. The "E" tires required 80 psi based on my axle weights. So per GY Tech Support I ran 85 for many thousands of miles with perfect tread wear.
3170 @ 85psi
3300 @ 90
3415 @ 95
3550 @ 100
3675 @ 105
3750(G) @ 110
About Fifth Wheel Group
