Cummins12V98
Aug 19, 2016Explorer III
Me Again wrote:
You are suppose to air to the heaviest loaded tire plus 5 lbs. His 10-15 was most likely to cover those who have not weighed each wheel position.
Chris
To be technical GY said to weigh EACH tire if possible and to use the weight of the HEAVIEST tire per axle, add 5psi to that weight. So it is possible to be running two different AXLE pressures especially if you are nose high for example.
About Fifth Wheel Group
