hbillsmith
Aug 21, 2016Explorer
TxGearhead wrote:
I could be all mixed up on this, but I THINK I have read that there is a different import duty on ST tires vs. regular vehicle tires. I believe I read that Sailun just re-branded the S637 tires to ST to avoid that. But I could be way off base on that.
You are correct on the import duty. Sailun markets two similar tires, close but not exact. The S637 is sold as an LT235/85R16 that is LT branded and has 2/32 more tread depth than the ST variant (12/32 vs 10/32). The S637 last year became available as a "Special Trailer (ST)" tire ST235/80R16. Both variants are "G" load rated, have a max speed of 75mph, and require metal stems and a wheel certified to 110psi.
It is not always simple to determine the psi rating of your wheels. Some are simply stamped with a load rating. A call to the wheels mfg. does not always get consistent results. For instance, my Forest River has HiSpec Series 9 Aluminum 16" wheels and when I called I was told they are good up to 80psi. Another owner called HiSpec and was told the very same wheel was good to 110psi as long as you added metal stems.
About Fifth Wheel Group
