Rough2000's avatar
Rough2000
Upgrading suspension on Jayco Designer
I have a 2009 Jayco Designer 34RLQS. I want to upgrade the suspension from the original nylon bushings and bolts to metal bushings and wet bolts. ( I know, should have done this long ago). What do I need to order, and where is the best place to order these from? As always, thanks for your help.
  • Thanks for the replies. Does anyone know who made the axles and suspension on the 2009 Designer, and what size axles were used on the 34RLQS? With my replacement knees, I'm trying to keep from climbing under my trailer.
  • Ordered my MOR/ryde LRE12001 Tandem Wet Bolt Kit from Amazon.com.
  • I ordered mine directly from Dexter, cheapest price I could find at the time.
    Double check to make sure you haven't had bolts spinning in the hangers, or such like that.
  • I ordered mine from here. Best price I could find for the Dexter E-Z Flex kit.
    https://www.easternmarine.com/
  • stickdog wrote:
    wet bolt kits for trailers That was easy.
    Not so fast skippy..... That link is blank .. ;)
    I just did the same update on mine ... I called MorRyde and spoke to the techs , they told me exactly how to measure for the proper fit ( if your also doing the equalizers) and I ordered everything from Makarios RV
