Bayley's avatar
Bayley
Upgrading to 18" truck tires
I have a 2013 Ram 2500 CTD 4x4 that currently has 245/70/17 tires on it. I am thinking about moving up to the 275/70/18 tires. Has anyone done this and are there any major draw backs in doing this?
Thank you for your input!
  • I did it, 265/70-17 to 275/70-18 and I could not be happier. I found a set of 18" alloy Big Horn wheels from a 2014 on Craigs list for a good price. I went ahead and had the wheel size reprogrammed as the speedometer difference irritated me and I hear the shift points would be affected. I picked up almost 1000 lbs of capacity over the stock wheels and the extra safety margin makes me feel better when I run heavy.
  • Actually, "truck" tires are 19.5", not 18". Rickson tires will sell you the wheels, and a variety of 19.5 truck tires, as well as programing your computer to compansate for the larger tires. They claim 8 plus years on a set of tires!
  • Price? That would be a deal breaker for me. I doubt other than bling you will gain anything worth while.
  • There are lots of 18" tire options out there these days. Should be no issue with the diesel going larger diameter tire. Your speedo will now be off by a couple MPH at hwy speed. Best to check it with a GPS.
  • I went from 17" to 18", but my originals were 265/70-17 and I went to 275/70-18, and it was on a Ford. Brand doesn't matter, but point is you are starting out smaller than mine. (just saw your edit on size - so you would be making the same size jump as I did)
    On the positive side, you get a higher load rating, a tire that fills the wheel house better (looks) and more ground clearance.
    On the negative side, you might have bed height issues under your fiver. Wheels - I found take-off OEM 18" wheels, which are hub centric. If you go with aftermarket wheels, I don't think there are any that are hub centric. They are all lug centric. Even though they are rated for the weight, I would hate running lug centric wheels under heavy loads. Fuel mileage - it will probably suffer a little bit. Power - it will suffer a little bit, but the CTD has plenty to spare. Tires will cost more. Not as good a selection in 18".
    The pro list is shorter than the con list, but I'm happy that I did it. The added load capacity alone is worth it to me.
  • Correction to my original post.....the current tires are 265/70/17.
