christopherglen
May 14, 2015Explorer
Sounds like someone found a tree, and busted the outside dome. When they found out how much the domes cost, they went for a $15 piece of plexi to cover the home, and flipped the inside dome. Replace the outside with the correct piece and flip the inside dome. You will be much happier.
Install is easy, remove the flat piece, and whatever sealant they used, clean the area (use rubber roof stuff). RV version of plumbers putty between the new dome and roof, screw to roof. Dicor over all edges and screws. Inside is super easy, pull screws, drop dome, clean both sides of dome, reinstall 'this side up' and screw in.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
