Ed9824v
Nov 25, 2014Explorer
oldelmer wrote:
If you Pull Rite is like mine, you can pull the 2 pins that hold the head on the hitch. This way the camper will lift the head up and off the rest of the hitch. Then just put the head back on.
this will work as a last resort by pulling the pins on the side of the hitch, but to do it correctly you will need to find the resting place of the hitch and it will release
I get it so I see light between the hitch and the trailers pin plate. if it does not release then put in neutral and try to take tension off between the two. If that does not work get some help to try to pull release lever while you move truck slightly back and forth.
About Fifth Wheel Group
