Coach-man
Dec 04, 2014Explorer
My experiance with the pull right hitch is if I raise the trailer to high, "looking for the light between the hitch...", is when I have a problem releasing the hitch. I try and get some weight on the front legs and the pull the lever, the trailer dose not drop but the TV comes up slightly when I pull out. When hitching, I pick up the front of the trailer when backing into the pin, bang it hitches just fine. I use a pad lock to keep the release lever in place while towing. That gives me piece of mind, and I have read where some smart A$$ will pull the release lever when your stopped at a rest stop and you start to drive off and then ....!
About Fifth Wheel Group
