schlep1967 wrote:
Do yourself a favor. Ignore anybody that tells you that you should see daylight between the plate and the pinbox. Look at the pin on the pin box. It looks something like an upside down "T". The latch part of your hitch fits between the the lip at the bottom and the flat at the top. If you lift the trailer until you see daylight you can pinch the latch between the bottom lip and the underside of the plate.
When hitching you want the pinbox to hit about the middle of the plate and ride up the plate and into the slot. When it goes in the the curved jaw will snap into place behind the pin.
When unhitching you want to raise the trailer taking most of the weight off the suspension of the truck. Make sure to chock the trailer wheels at this point. Then put the truck in reverse and ease back. Set the parking brake. Then put the truck in Park. Now go see how easy it is to unlatch the hitch. Unhook cord and brake safety cable and ease the truck out from under the trailer.
Ignore the first sentence!
The "anybodys" are referring to UN-hitching.
("bpounds")- "Scariest thing" = Wow! - Very! ..:E
OP - No disrespect intended, but a thorough inspection of your hitch *for damage* is in order by someone other than yourself!
A Blue Ox Bedsaver might be a good investment also.
BTW - prime example of "why" to tell folks asking where/how to jack trailer wheels off the ground - to *NOT* jack under the axles!
The mechanical skills & ability of the person asking is *unknown* on a computer monitor..:R
