Old-Biscuit
May 12, 2014Explorer III
fj12ryder wrote:the bear II wrote:May not work on my triple axle, or do you have to have 2 of them. :)
never the axle...spring plate or frame.
Best method is to use something like this which is a lot easier and quicker:
http://www.campingworld.com/shopping/item/trailer-aid/10867
Don't know about triple..best guess is it won't work
I do know it won't work on my double axle 5vr.
Can't get enough lift to raise the other axle/tire off ground
I jack under axle right where the springs are attached.......all of the trailer weight is suspended/support at that location on each axle so my jacking p wheel there is not going to hurt anything.
Besides.....I would have to build crimping 12" high in order to use a jack on frame. And that AIN'T happening on the side of the road!
OP......re: your other earlier post in another section of forum
IF it was that big of a deal........moderator will move the post.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
