dezl_dr
May 12, 2014Explorer
Had my last rig for 13 years and can't even count all the times I jacked it up. At the very least each tire once a year. Each time I put in under the axle and normally under the ubolt. One the side of the road with a flat I wasn't so picky about it.
It's a round axle, they'll never tell you to jack it up on that. Just the way it is. With a bottle jack that has the vee notches on top it works fine. Just stay close the wheel or you will bend the axle tube. I put it with the jack against the tire if it's flat.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
