N-Trouble's avatar
N-Trouble
Useless gutter spouts
Have found the factory gutter spout/extensions on my 5er aren't doing the job. Much of the water still runs down the side as can be seen by the dark streaks running down from them. Spouts are clear of debris and trailer is perfectly leve. I have the same streak down both sides of the front of my 5er. Are there better options out there?
  • RoyB's avatar
    RoyB
    Explorer II
    I also have black streaks running down my rear picture window area on my 5th wheel trailer... I think one could solve the problem by placing a long 1/2-inch angle strip across the roof near the rear edge. You can use Dicor Sealant (No screws) to hold the aluminum angle strip in place. This would route the run-off water to each side of the roof to run off using those add-on spouts you are referring too.
    I purchased the aluminum angle strips but never got around to installing it... haha
    I got the idea from my OFF-ROAD POPUP trailer roof area which already has this J-strip rain gutter installed like shown in this GOOGLE on-line photo.
    Roy Ken
  • I don't have that problem with my current camper and the factory installed gutter spouts, but my previous camper did. I replaced the short spouts with longer ones, and never had the problem of streaking again, if so, it was very minor. Worked well for 8 years.
  • MIKECBROWN wrote:
    A wooden clothes pin clipped on the gutter works amazingly well. The water follows the clothes pin. Send me $39.95 (plus shipping) for a set of 4 genuine WOODEN RV GUTTER EXTENSION CLIPS.
    Spoken like a true entrepreneur. You're good. :)
  • We put the gutter extensions on ours and they work very well. Anything that gets the water out a little farther would do the trick.
  • A wooden clothes pin clipped on the gutter works amazingly well. The water follows the clothes pin. Send me $39.95 (plus shipping) for a set of 4 genuine WOODEN RV GUTTER EXTENSION CLIPS.
