kelly4hand wrote:
I see....the power pole that the 30 amp plugs come off of, ( and there is actually 4- 30 amp plugs in total) the box says " general duty, 200 amp  240 V.AC MAX HP 50 " if that helps any.....i don't understand the boat comment
Because in boating world/dockside with power it is common to use this double 30A to 50A adapter because the 30A are not wired from same hot leg. One will be wired from L1 and other will be wired from L2 so that when you plug in the double 30A to 50A you are getting balance power
Not knowing how CG pedestal 30A is wired I would not want to have 50A with both hot leads from same leg
With the notation '200amp  240 V.AC MAX HP 50' and 4 30a more than likely 2 hot legs were used.........but which 2 are on same and which 2 are on other????????
That 4 outlet power pedestal is for 4 different 30A RVs to  use
