Halmfamily
Jul 28, 2013Explorer
I take two temps on each wheel, one on the brake bub and two on the tire itself. Naturally brake hubs will be hotter than tires. Temps on all hubs should be pretty close to each other, same with the tires. If one temp is much higher than the others then you have an issue with that hub or tire. Cannot tell you what temps to look for as mine will vary according to speed, outside temp, weather etc. Goodluck.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
