- mapguyExplorerIf the spare has sufficient load capacity -it will technically work.
But -if the take offs are not good enough for use as they were -why would you set up a potential future problem if you get a flat in a remote place....Buy a 5th tire and sell all the take off's on craigslist. - JIMNLINExplorer III
rtaylor0830 wrote:
I am getting four new tires that are grated for my camper my question is if they are the same size which they are can I still use the e rated as a spare
As long as the E spare has the proper load capacity its good to go. However just remember on wet roads the spare has a different tread design/maybe a different pressure rating (80 vs 110 psi)/tire diameter/etc will not have the same "grip" and may slide before the others.
My spare tires on my equipment/boat and RV trailers seldom ever see road service. - naytherExplorer
Second Chance wrote:
fj12ryder wrote:
I run "G" rated tires but have an "E" rated spare, but I don't rotate the tire locations. I figure they'll age out before they ever get the chance to wear out. :)
X2 ^^.
Rob
x3 plus since my spare is up under the trailer it never sees any direct sun, which does the most damage to rubber so it should last a long time. I do usually rotate it in when I get new rubber, take the newest/best tire as a spare when replacing. - Second_ChanceExplorer II
X2 ^^.
Rob - azdryheatExplorerI don't rotate my tires as they are wearing fine. The spare is a Chinese May-Pop so it'll remain a spare.
- fj12ryderExplorer IIII run "G" rated tires but have an "E" rated spare, but I don't rotate the tire locations. I figure they'll age out before they ever get the chance to wear out. :)
- Dick_BExplorerThere is a school of thought that recommends that the spare be rotated into the mix when the main tires are rotated. That would necessitate that the spare be the same tire as the others.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 24, 2025
