r47smiley's avatar
r47smiley
Toyo F Rated Tires
Hi All,
Had our first experience using a TC last weekend with my wife and daughter (and our boat). Had a great time!
I haven't decided which camper to get but am planning to do so in the spring, I have connected with a local guy who is renting us his TC when we want to use one. My current truck tires were not purchased with the idea of carrying a TC. I have BFG KO2's 35x12.5r18 that have a max cold psi of 65. The TC we used is very heavy but it was a good experience, a Lance 855s.
These are going on my 2012 F250 CC SB 4x4 with a 6.7 diesel and I tow my 22' aluminum jet boat. I know this isn't the ideal truck for what I am wanting to do but it is what I own so I'm going to make it work. I understand the general concurrence is that a slide out camper should be on a swb dually, but that isn't going to happen. I've done a few upgrades to help carry a TC (I understand that none of these increase the vehicles rated capacity), Big Wig sway bar and airlift 5000 air bags, but with my boat in tow, some helper springs are needed too.
Toyo's newer option for a f rated tire in my same tore size that can go to 80psi and is rated to almost 4000lb is tempting. I feel that the extra 15 psi and stronger sidewall would have made a big difference on the sidewall compression and roll caused by the tires. I will not be putting 19.5's on so this seems like the next best thing.
Any one have experience with these?
http://media.toyotires.com/press-releases?item=122476
Thanks, Rob
