arubaExplorerJun 03, 2013Using "maneuvering" position on sliderHi, Normally, if you are backing into a tight spot, do you need to unhitch the FW, slide the hitch to maneuvering mode, re-hitch and proceed to park? Or do you simply remove the safety pins, and mo...Show More
Pete_kExplorerJun 04, 2013Never lower my landing gear. Just move handle and put trailer brakes on. Full forward and its done.Pete
Related Content202" WB maneuvering into site?SliderTowing with slider in extended position?slider hitchLightest slider hitch?
