linnemj
Nov 21, 2013Explorer
If you are refueling at truck stops, it is good to have some gloves. I have found most places have fuel on the handle and tend to be messy. You can use the same disposable gloves used when dumping the tanks.
I prefer using regular diesel pumps when the spacing allows. Some of the truckers take some time to fuel and then pull up and block your exit. Truckers will pull up and then head in for food, ect and you may sit for a while.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
