retispcsi
Nov 21, 2013Explorer
Yes you can use truck stops and many now have a pump island for use by pick-ups etc. with a car type nozzle. But truck stops are more expensive and the islands areas on the ground are usually stained with diesel. The large nozzle will work in your truck just be careful. I have done it many times. I perfer Murphy Bros. (Wal Marts), Sam's, Racetracks etc. because the cost of the fuel can be anywhere from 10 to 40 cents a gallon less expensive. I just did a 5100 mile trip and the fuel cost can add up. I do not use stations that look old and unkept. I pull a 37ft. fiver and although sometimes it was tight I have never been stuck in a station. I installed a 60 gal. RDS aux tank and that is great. I buy fuel when and where I want for the best price around. Good luck and just my two cents worth.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
