laknox
Nov 21, 2013Nomad
Rogue Eagle wrote:
I am new to rving and would like to know if I can use truck stops to refuel my diesel pickup with 5th wheel?
One issue that I didn't see mentioned is that the truck pumps often times use a much higher-flow pump so foaming can be an issue. I know that, even at a regular pump, I can sometimes have venting issues when the handle is opened wide. This will cause the handle to shut off. When that happens, I have to use a "lower" notch to reduce the flow. Just one other thing to keep in mind. I always carry leather work gloves in my truck and use them when fueling. As others have said, remember that the truckers are working, so be courteous to them.
Lyle
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
