VinnyPExplorerMay 19, 2013Valve Stuck OpenSo I was dumping my black water tank this morning. Everything was fine until I tried to close the valve. It was stuck solid in the open position. Would not budge a bit. I tried spraying a little WD...Show More
HappyKayakersExplorer IIIMay 19, 2013Time to drop the underbelly, or cut into it, starting where the valve handle is attached to the frame.
Related ContentSewage valve stuck openstuck dump valvePropane tank valve - stuck solidWater Heater Gas Valve Stuck Open UPDATE-Bench TestGrey valve open
