Me_Again
Oct 20, 2018Explorer III
If your state licenses tonnage make sure you are licensed for 11K or 12K and trailer on. Your truck should have a 6500 RGAWR and you should be under that. GVWR is a manufacturers warranty issue. No pickup will exceed the the Federal Bridge Weight laws. Your 2500 has rear coil springs verse the leafs or air on the 3500 with a 7K RGAWR.
If correctly licensed, you should be fine. Search Wadcutters posts on weights here in RV.net for more info.
About Fifth Wheel Group
