Golden_HVAC
May 17, 2015Explorer
debraindi wrote:
That was confusing I thank the trailer brakes should come on stronger first to prevent from heating up the truck brakes .
In other words your thought is not to worry about overheating the trailer brakes, but worry about overheating the much larger and stable disk brakes on the pickup?
I don't like the drum brakes that came with trailers in the 70's and today they are not much better. While drum brakes are a thing of the past for most cars and heavy trucks, disk brakes are standard on most car front axles. Disk brake systems for trailers have been around for about 15 years and work much more effectively than the drum brake and magnet system.
The brake controllers are better than in the 70's but the brakes on a trailer can overheat. There is not all that much cooling surface, and typically they will not use aluminum rims to assist with that cooling.
As for the original post, I would be happy and comfortable towing a trailer that is barely any more weight than the truck pulling it. Even at twice the weight of the truck, the load can still be stable.
Fred.
About Fifth Wheel Group
