When I read your post I heard that you went camping, used the toilet with no chemicals in it, then drained the tanks, and then you added chemicals after you where done using it. No wonder it stunk! You first put in the chemicals with water, then use it, then you drain the tank of the chemicals and what ever you put in the toilet! Chemicals first and not last when you are done. When you put the chemicals in with a little water and let it sit for several weeks the chemical lost its potency and things got stinky. Chemicals need to be renewed in order to keep working.
