mtofell1's avatar
mtofell1
VERY strong sewer odor
2016 Keystone Hideout, 2 months old. I've used it twice for a couple days each time and emptied the tanks each time and filled with chemicals and a couple gallons of water. In preparation for leaving tomorrow I went out and flushed the toilet and was overtaken by a ridiculously strong black tank odor. It was so "gassy" I felt like it would explode if I lit a match.
I understand all about plumbing and traps and this is my 5th RV. I visually looked at all sink traps and verified they are holding water. While the odor does seem to be strongest at the fixtures it's kind of just all over. Honestly, it's tough to tell where it's coming from (other than the black tank, of course :)) I'm suspicious of a detached vent pipe in the wall. Does this ever happen? How would anyone find it?
I added another bag of chemicals and another gallon or so of water and will recheck in the morning. I'm 99.99% sure I put chemicals in after last draining but I suppose I could have forgotten - new trailer, new routines, etc. but I really don't think I did.
Has anyone experienced anything like this before?
  • momentum rv wrote:
    If you have a black tank flush, you may have a stuck open vacuum break/check valve in the flusher line.
    As mentioned above it could be your gray tank. check AAV under sink. It may be stuck open.
    AAV = air admittance valve
    I second the AAV under the sink. On my new rig, the AAV failed, and the whole rig reeked. A trip to Lowes and $25 later, the fix was in.
    Jim
  • If you have a black tank flush, you may have a stuck open vacuum break/check valve in the flusher line.
  • Grey tanks can smell as bad if not worse than black tanks especially a galley tank. Food particles in the grey tank breed bacteria that really smell. Try putting chemicals in your grey tank also. The warmer the weather, the worse the grey tank gets.
  • Black tanks are vented through the roof. Make sure your roof vent is clear. I would also double up on chems next time and use LOTS AND LOTS of water. I usually fil lthe black tank to at least 1/3rd full before ever using it. More water the better. It is very hard to fill unless you areout for long periods of time
    Chris
