Baja_Man's avatar
Baja_Man
Vinyl Fence Posts as Sewer Hose Storage - A few questions?
Hello all-
I really like the idea of the vinyl fence post as sewer hose, fishing rod storage, and misc storage.
I would like to add 3 to my 5er:
One on top of rear bumper for misc storage and 2 in front of tank drains between tank drains and landing gear (one for sewer hose keeping it close to drain valve/fitting and one for rod storage),
Questions:
How can I mount two under my 5er? My frame is square tube type and there is no way to get something around the tube. Only option appears to be drilling into frame. I hate to do that if not necessary.
Will these holes for screws weaken frame? If done this way I was planning on using some zinc plated 16 gauge angle iron with pre-drilled holes (sold at Lowes). I would use 3-4 #14 metal screws into frame and the angle iron piece would be long enough to accommodate two fence post (about 13" long which allows 1" inch in between post and 1" on each side for all thread rod). I would do the same for left and right sides of trailer frame. This would give me a bracket to use all thread rod (vertical) and use 13" bar stock pieces to hold bottom of fence posts. I could also use bar stock with nuts on top to space the fence post just under my LP gas line which runs against and under trailer frame.
The bar stock would sandwich the fence posts.
Do you drill holes in sewer storage and where and how many?
I wouldn't think holes are needed in rod storage or misc storage or do they?
What else do I need or have not thought of?
Thanks
  • word to the wise on painting the fence post: I would stay away from dark colors as when I painted mine(black) that was mounted on top of my bumper it absorbed so much heat from the sun it softened the pvc to the point of caving in.
  • Thanks to all for their pics and advice. I didn't pit any hinges on my door only a latch. I thought the screws heads/nuts could damage the hose when sliding in/out. I also added a second vinyl gutter under my sewer slide for use when laying out hose to drain at campground; it will keep my hose off of ground and protect it. Since it gets pretty hot out here in summer, I decided not to paint and just leave white.
    I used stainless hose clamps (one 7" and one 2" connected together) to attach to bumper.
    One mod I'm going to try tomorrow.....
    I'm going to see if two vinyl gutter pieces will fit inside bumper as I would like to carry two. The one that my hose sits in has a stopper at both ends therefore can not be used to support hose when connected to drain at campground due to the stops. Also, it slides smoother when only one gutter is being used and gets a little tighter when I added the second piece of gutter.
    Below are pics of my project. The other two I will install just behind landing gear and will open from door entry side (passenger side).
