mpierce's avatar
mpierce
Voltage 3600 fuel pump switch
I have a Voltage 3600, with the two 30 gallon gas tanks and a pump on one for toys. How do I turn on the pump? There is a door back by the tanks, that has a switch and a gauge. It says to press the switch twice to tun the pump on, but it does not, nor does it turn the gauge on.
I looked at the switch board inside the coach, and there is no switch there.
Is there another switch inside, or elsewhere, that needs to be turned on too?
Thank you
  • Thanks. I will check for that fuse. There is a 20 amp fuse in the panel inside, but it is OK.
  • Like it says inside the door, press the switch twice and the pump should start and the gauge is activated at the same time. That is how it works on my 3200. There is a fuse behind the panel, that you may or may not be able to get to. Look underneath and there should be an opening in the metal that you can get your hand into to check for the fuse.
