joebedford
Sep 19, 2013Nomad III
SpencerRB wrote:I notice that the cranks are in different locations on the two essentially identical (in that area) RVs. I wonder if there is a reason or it's just the installers slapped it in two different places just because.
Joe,
I investigated this a bit further and found that my '11 3905 antenna is mounted further back between the bathroom vent and main A/C but there is still not a 66" clearance to fit the Sensar antenna.
It looks like the later models relocated the antenna to the left side of the roof, above the bedroom "hallway."
Here you can see a couple high res pictures on the Voltage website. If you zoom in, you can see the crank on the ceiling. First is a 3950, second is a 3905.
3950
3905
Hope this helps. I may just go with the Jack antenna in the stock location to avoid new holes/wiring.
Did you try the Jack antenna? I'm concerned that because it's right behind the air conditioner the signal might be blocked. I guess direction is important.
Eyeballing it, it would appear that the current antenna is directly above the track for the bathroom door.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
