- buckyExplorer II
- Queen_s_CastleExplorerMore specifically, it is a Cummins diesel. Does that change the answers? Thanks guys, for the responses.
- wolfe10ExplorerNotify moderator function not working (again).
A duplicate of this post in Class A section. Probably better there. - Optimistic_ParaExplorer
riggsp wrote:
Most later model voltage regulators are built into the alternator.
Actually, on most later model engines, the voltage regulation function is handled by the engine control computer. Whether a 2002 model did it that way, I couldn't say. Older model GM products did indeed use a regulator that was built in to the alternator, while Ford and Dodge vehicles still had separate voltage regulators. You could buy the GM regulator as a separate part if you were willing to disassemble the alternator to replace it. (I used to sell auto parts.)
Bottom line to the original poster, you may not have a separate voltage regulator. - buckyExplorer IIChevy or Ford?
- riggspExplorerMost later model voltage regulators are built into the alternator.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 20, 2026
