rayford118 wrote:
im typically more on the fringe too about the weight policy but decided it would probably be a lot better to just go dually.  going to suck when im in town but i also see other people doing it all the time so it can be done i guess
i like the XLRs too but main negative for them is the nearest dealer is 3.5 hrs away.  if issues happen thats a long way compare to 1.5 hrs of the cyclone voltage dealer.
I'll try to cover a number of things with you, hopefully without sounding too much like "weight police".   :)
I currently have a Heartland 3950.  Verified pin weight is 4,300 lbs.
Running weight, without any toys, is a verified 16.5K.   Add my golf cart and it goes up about 800 lbs.
I'm guessing just about any of the units you mention is going to be a comparable road weight.
Wife and I are kicking around replacing our unit and have looked at the King, the XLR 415AMP, and a Voltage model # I don't remember.
King:  I liked it well enough, though don't really care about a bathtub.  Rather just have a nice shower and extra space.  Lack of storage space in the kitchen was a biggee for the wife.  King size bed is a big plus.  I LIKE hydraulic slides/landing gear, though I do wish the slides could be handled individually.
XLR:  Front runner for us at the moment.  Double fridge, way more (apparently) storage space in the kitchen, King size bed.  That's a requirement so we can be semi-comfortable when our dogs allow us to join them in "their" bed.  I know at least one slide, and the landing gear, is hydraulic.  Not sure about the remaining slides, and not sure why they would NOT be hydraulic, but factory info raises some doubt on their actual status.
Voltage:  Seemed like a nice enough unit, but I thought the price was just a tad on the stiff side for what amounted to not much more than surface bling.   Don't ask me to quantify the validity of that statement because I can't really.  I just remember it being my opinion at the time.  I remember there being a bunch of complaints about slide issues with the Voltage line.  This may or may not have been rectified by now.  Slide issues, such as leaking, worry me way more than faulty landing gear or other failures of the widget variety.  Leaks can cause major messes.
Dually:   I drive an '08 F450 as my daily driver and so far there has been nowhere I have not been able to take it.  No drive through, no ATM, No Where.  I will admit to shying away from parking garages but that has less to do with it being a dually, and a whole lot to do with it being a truck, which tend to be on the tall-ish side.
The F450 allows me plenty of cushion weight wise on the factory recommended capacities.  I am perfectly happy to stick to factory recommendations and relieve myself of the necessity of playing arm chair engineer.
With THAT said, you might want to check into cost, registration and insurance issues concerning said F-450.  If there is not a significant cost difference, and if there are no registration and insurance complications, it might bear looking into, for a couple of reasons.
One is it allows you that capacity cushion, and two it comes with a wide track front axle that offers an unbelievable turning radius in a full size truck.   Mine turned circles around my Excursion, and would have turned circles around my F-250 CC short box.
The turning radius was an unexpected but extremely welcome surprise after I bought the truck.
All the truck info is based on an '08-'10 F-450 Superduty.  The new ones are not the same animal, in spite of their ratings, so I can't speak to them.  I'm not even sure about the wide track axle on the new models.  As an example the rear axle in my truck (Dana S110) is rated by Ford at 9,500 lbs.  The rear axle in the new 450s (Dana 80) is rated by Ford at 9,500 lbs ( I believe).  My axle is rated by its manufacturer (Dana) at over 14,000 lbs, and was designed for medium duty commercial trucks.
Anyway, the point is that if there is no significant monetary difference between the 350 and 450, why not bump it up a notch?
