enblethen
Jan 02, 2017Nomad
Your incoming voltage is a little low, but no the problem.
Sounds like a bad connection.
Verify voltage in 12 volt DC distribution center. Check both sides of the BAT fuse.
Check ground connection on tongue of the rig where the ground wire attaches.
Look under tongue where the umbilical cord from TV connects to battery positive wire for a circuit breaker or fuse. Doubt whether it is tripped, more likely to be corroded.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
