time2roll
Jan 02, 2017Nomad
13.7 to 7.5 is huge. Especially with no load. Almost as if a switch is off or the self resetting breaker is shot. Anyway you need to trace out the connections. With no battery the voltage at the converter and the battery should be identical. Start poking your meter on every connection until you find 13.7 on one side and 7.7 on the other and fix that item or connection. Could also be at the ground connection to the frame.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
