Sam_Spade
Jan 02, 2017Explorer
doug90000 wrote:
Checked the voltage at the DC lugs in the battery compartment with batteries removed and the voltage is 7.5 VDC.
You need to check the voltage output AT THE CONVERTER under the same circumstances; that is within a minute or two of the above measurement.
With the batteries removed, there shouldn't be enough current to make an actual voltage drop so the best guess is a REALLY bad connection between battery and converter somewhere.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
